Status
Not open for further replies.
1 - 3 of 3 Posts
I can use VMR9 with any filter on my old computer.
On my new HTPC, if I try to use VMR9 it will freeze by computer forcing a hard reset.
I have installed DX9, and using ZP 3.0 I have changed the VMR9 merit to 80000. I have tried various combinations of forcing it, etc., with ZP. Everytime I try using it, everything freezes.
Overlay works fine with everything.
Any clues? This is driving me nuts...
Banned
Another idea - do you have the DirectX SDK (software developper kit) installed? Particularly if you install it in debug mode it can cause some VGA drivers to become unstable.
If you have DX SDK installed, try uinstalling it, and using DX runtime.
Also - make sure your VGA card drivers are up to date. If possible use a "signed" WHQL certified driver version.
1 - 3 of 3 Posts
Status
