Tom,
Are you saying the optical DVI cable looked better than the 10 ft normal DVI cable?
That seems hard to believe. Unless, you were having some sort of transmission problem, the 10 ft should have worked perfectly. Not to mention any transmission problem would have been fairly obvious with pixel break up type artifacts (i.e. obvious noise).
I would also like to point out that at up to 10m, people shouldn't have any problem with plain-jane DVI cables at normal HDTV resolutions (720p, 1080i which are
