I bought this 1030q and have it working good with my compuer and matrox card, but I am experimenting with a borrowed hdtv tuner box with vga out, I cant seem to get the picture to display without the screen rolling, I know this pj should be good for 480p and that setting doesnt seem to work, but if i set it to 1080p it displays a picture, be it cut off, do i need to adjust something or will this not work for some reason? Thanks
I got an extron 118 plus, but it has a 9pin input and 4 bnc output, can I just make an adapter from 4 bnc cable ends soldered to a 15pin female end and connect this to my 15 to 25 pin cable, and solder a 9 pin connector on to a 15 video cable? I tried it and it isnt working, not to say i may not have a wiring issue. How do you connect it up?
pin - It sounds like you got just the Extron box without the input cable. I don't recall what the wiring scheme is for the 9pin - 15pin setup you need. If I get the time I'll check my cable and post back with the pinouts
As for the 4 BNC outputs you could find a 5 BNC -> HD15 (vga) adapter cable. They sell on Ebay for less than 10 bucks. Most Extron boxes will adapt to them without issue.
