Status
Not open for further replies.
1 - 4 of 4 Posts
What I'm wondering is...the manual gives computations for throw distance based on screen size...but there are also picture size adjustments on the projector (presumably can go in both directions). If I want to maximize the phosphor area used (i.e. turn the picture size up as high as possible without distortion) how much closer can I make the projector to the screen? Is this a wise thing to do, or will I regret it as the tubes age (they were replaced recently, before I bought it)?
Also, if I have a 4:3 screen that I will also use for 16:9 (by not pulling it down all the way) will I be able to memorize settings for both screen sizes? As far as I could tell from the manual, there's only one setting for each range of vertical refresh rates.
Steve
Steve
It should be safe to go around 5% to 7% closer to the screen, if I remember correctly. I did it my 1272 and there did not seem to be any distortion. It is a good thing to do, longer tube life and increased resolution.
Deron
Discussion Starter · #3 ·
Thanks...anyone know about memorizing different picture sizes with similar scan rates?
Steve
Steve,
You can memorize more than 8 different setups using the "5BNC" mode. Do a search on this forum for the details.
1 - 4 of 4 Posts
Status
