Status
Not open for further replies.
1 - 8 of 8 Posts
I am trying to plan ahead and order a ceiling mount for the HS10 but
I am not sure what choices I have besides the pss-610. Someone
mentioned to me that the peerless mount will work but I not sure which
one. Is it the (PJC-140)? What accessories will I need if I am mounting it
from an 8' ceiling?
Thanks in advance,
--Paul
Paul,
I mounted mine to a piece of melemine and then screwed that into the ceiling. Only temporary for me, but it was very fast and easy.
If you would like you can come by and check it out.
Discussion Starter · #3 ·
Styk33,
Thanks for the offer but, I think that I would like to buy a ceiling mount to avoid any hassles.;) I want to be able adjust the angles and height easily.
Thanks again,
--Paul
Premium Member
OhioGuy, I think that was me who posted that link :) (which was very helpful to me anyway)
From what I can tell, you'll need (at a minimum):
Peerless PJC-SNY1 (the two-piece part that mounts to the projector and to the ceiling plate)
Peerless ACC-571 ceiling plate (for a flush-mount installation)
Peerless ACC-570 ceiling plate (for an installation where an extension is needed)
Peerless extension
Many folks have stated that a piece of threaded pipe works just as well as any of the fixed-length extensions, but I need an adjustable extension, so I get to pay an extra $85.
Discussion Starter · #6 ·
Thanks OhioGuy & Schwa,
Schwa, thanks again for your help. I forgot that you were the one that mentioned the peerless to me. I still have to figure out how long of an extension to use but at least I know now what to look at.
--Paul
Premium Member
Mike is right. The PJC-173 is the mount that's designed for the HS10. Some people have gotten the PJC-SNY1 to work, but I know it didn't work for me.
1 - 8 of 8 Posts
Status
