Status
Not open for further replies.
1 - 1 of 1 Posts
Vr-5900 HELP!!!!!
I have the VR-5900 and I am trying to hook up a 4yd old Mitsubishi VCR to it thru the composite cable then send the composite signal unconverted to component thru the receiver to my Sony Hs-10.
The problem I have is the VCR tape will play and show up on the screen ranging from a few seconds to several minutes then the screen blanks out and comes back usually within 5 to 10 seconds later. Pretty annoying say the least.
Do you have any ideas what might cause this? I am thinking about getting a new S-Video VCR to see if this problem goes away. I called Kenwood technical support and all they said was they would forward my problem to their engineering group. The tech thought on the phone it might be a Macro Vision problem, which I have no idea what that even is.
Any help is appreciated.
Jose Lozano
1 - 1 of 1 Posts
Status
