1 - 20 of 31 Posts
I am trying to decide between the three listed in the title. I will use it for both Music and HT. The center and the surround will come later. The room dimensions are 16X17X9. Mostly listen to rock and jazz. I have a Martin Logan Dynamo 500 subwoofer. Will probably replace that by a Rythmic at a later date. Any insight or actual listening experience will be most helpful. Receiver is Yamaha RX-V3900.
Thanks...
Originally Posted by neelic  /t/1494555/vsa-vr-22-or-salk-strt-or-philharmonic-slims#post_23828259
Thanks...
Re: the Salk STRTs, have you read through the Salk threads here at AVS as well as at AC ?
Here's what I had to say .
Discussion Starter · #4 ·
Thanks charmerci and laulau. I have been following the Salk and Philharmonic threads here on AVS. I had pretty much decided that it's going to be either the STRT or the Slims. Then I read about Von Schweikert VR-22. Unfortunately I did not find much information about this particular model. There are a few professional reviews. However I consider real owner reviews in forums like AVS a lot more valuable.
So if someone has heard both the VR-22 and either the STRT or the Slims, I will be very interested to hear how the VR-22 stacks against the others.
I'll also very interested to hear about any other speaker I should be considering.
Thanks, again...
Of the three: my only experience is with the Salk STRT's; though I own both SCST's and Philharmonic 2's.
Because I have not heard two of them, and have no experience with even a relative of the VR-22, I cannot truly say something like "this one is better"; but as a very happy Salk ST owner, I can certainly put in a recommendation for that speaker.
Thanks...
I don't think you're going to find someone who has heard both the Slims and the VR22, at least not under conditions that would permit a valid comparison. Where are you located?
I gave it the old college try, but it never worked out. I really liked all your options(I heard the Phil 2s, not the Slims, but they are supposed to be very close). Bet you would be happy with any of the three choices.
Premium Member
"The Philharmonic “Slims” Tower provides the same clarity and imaging depth of the Philharmonic 3 but with a much smaller footprint and only slightly less bass extension. The RAAL ribbon tweeter is retained, and bass is provided by the 7-inch version of the ScanSpeak Revelator. An excellent 4-inch titanium midrange is used in an open-back configuration. This unit is often used as a full-range driver and features a Neodymium magnet that allows an unobstructed flow of the rear wave. The crossover design and component quality are equal to the Philharmonic 3. The sound of the two speakers can only be distinguished when there is very deep bass content below 35 Hz. Pricing begins at $2700/pair. A version with a premium cabinet built by SalkSound is available for $3050/pair."
http://www.philharmonicaudio.com/folio-me/html/Phil%20Pages/philslim.html
Discussion Starter · #10 ·
Originally Posted by Dennis Murphy  /t/1494555/vsa-vr-22-or-salk-strt-or-philharmonic-slims#post_23833629
Hi Dennis,
I have exchanged a couple of emails with you regarding the Slims in the last few weeks. My last email to you was about the various cabinet options. I was more or less decided on the Slims when I sent you that email. Then I heard about the VR22 and it piqued my interest. Hence this thread.
I live in the bay area in CA.
Thanks...
Ascend Acoustics Sierra Towers with the RAAL upgrade is another comparable option, both in terms the SQ and price. Since you're in the Bay Area, I'm sure you could easily set up in-home auditions for all the candidates, just not side by side.
Originally Posted by Kisakuku  /t/1494555/vsa-vr-22-or-salk-strt-or-philharmonic-slims#post_23836601
Well, I'm afraid that would be a pretty expensive audition for the Slims--trans-continental Fed Ex shipping. Now, if he were located in the Chesapeake Bay area, things would be more manageable.
Originally Posted by Dennis Murphy  /t/1494555/vsa-vr-22-or-salk-strt-or-philharmonic-slims#post_23836712
I see how this could have been confusing. I meant in the homes of present owners.
Originally Posted by Kisakuku  /t/1494555/vsa-vr-22-or-salk-strt-or-philharmonic-slims#post_23836758
Right--see Dave and Albert both build their speakers in California. That's what cornfused me. But still, I don't think there are any Slims owners out there. Just East Coast and Colorado, I believe.
Originally Posted by Dennis Murphy  /t/1494555/vsa-vr-22-or-salk-strt-or-philharmonic-slims#post_23836890
Well, maybe a Phil3 audition then?
Discussion Starter · #16 ·
That is a good idea. Has anyone heard both the Phil 3 and the VR22? If anyone has heard just the VR22, please post your impressions. I understand that chances of hearing both is slim. Thanks...
Originally Posted by neelic  /t/1494555/vsa-vr-22-or-salk-strt-or-philharmonic-slims#post_23837329
Actually, the Phil 2 would be a closer match. There are plenty of those on the West Coast, but I think they hop skip and jump over the Bay area. All you people in the silicon valley want more expensive speakers than I can provide.
Discussion Starter · #18 ·
I am also considering the Odyssey Lorelei. I learned about it today. This is more difficult than I thought.
Originally Posted by neelic  /t/1494555/vsa-vr-22-or-salk-strt-or-philharmonic-slims#post_23837589
Since you are open to speakers it seems like I highly recommend the Fritz Carbon 7. Although the bass wont be as deep as your initial choices since bookshlves vs. towers, it sure will be better defined and natural and you wont miss the bottom end because the bass going down to 35hz is so damn good on the Fritz.
Also, the Evolution Acoustics Micro Ones are good. I heard these today with a darTzeeL set-up and man it was magic although the electonics played part of it. These speakers are special just like the Fritz. I have not heard ANY bookshlef speakers that have better bass than the Fritz and I have heard ****LOAD of speakers.
If you can somehow get the MicroOnes at the orginal price of $2,000 delivered , they are a fantastic deal.
Just to give you an idea, overall, the Micro Ones are in a different league than the KEF LS-50's and the Fritz Carbon 7's are better than the Micro Ones. But, the Carbon's are $500.00 more than the Micro Ones. If you cant get it for $2,000, the Fritz are your best choice for under $2,500 speakers to date.
Premium Member
I heard the Fritz LS7's at RMAF this year and was not impressed at all. Perhaps it was a set-up issue but I've heard better sound from a Bose wave radio. Not impressed for a $3,500 pair of bookshelf speakers.
1 - 20 of 31 Posts
