1 - 4 of 4 Posts
I've got an old vsx-53tx that doesn't output sound via the speaker terminals, aside from the occasional sound which is extremely similar to a lightsaber. Despite how cool that sound is, I wanted to see if there is a particular component I should look at replacing in order to fix this.
Can't tell you what could be wrong. but maybe you could sell it to some geeky Star Wars fan boi
Discussion Starter · #4 ·
Originally Posted by jdsmoothie /forum/post/19595779
Pop the top .... perhaps you've got Yoda hidden away in there.
I took the cover off. Nothing obviously wrong though. No noises coming from any components. No smells, no magic blue smoke, no brown burn marks.
I was just curious if there were any components in particular I should look at. If I had to take a guess, despite zero expertise on the mechanics of amps, I would guess that the high regulation audio power transformer took a hit. But, I have no way of knowing or confirming.
1 - 4 of 4 Posts
