I got my Pioneer VSX-919AH today and have everything hooked up.
HDMI to the TV (Samsung LED DLP).
Wii and Xbox 360 are using component inputs to the receiver.
No issues with the Wii, but my Xbox 360 won't display 1080p. If I set the Xbox to 1080i, 720p, or 480p, I get a picture. But TV says no signal on 1080p. If I hook the xbox directly up to the TV, I get 1080p.
Also, My old receiver (VSX-D514) was 100 watts per channel, this one is 120 watts per. I have this new one hooked up using bi-amps to my B&W's. It seems I have to crank this receiver up higher to get the same loudness out of it. It might have something to do with that MCACC setup.
And thirdly. I have my turntable hooked up to this receiver via an external pre-amp as well. If I use the true direct setting, it sounds horrible. My old receiver had no frills and sounded great with this turntable.
Thanks in advance.
Thanks in advance.
