Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
I am using my VT540 via component using RP91 Progressive DVD, pictures
are wonderful. Question, with options on the projector should I select
HDTV/ or SDTV??. Does it really makes a difference in terms of resolution?.
Not really. It's more for color. I like the SDTV on my LT150 (same software menu as VT540) over HDTV setting for component. Try both and decide for yourself. It won't hurt anything to try.
1 - 2 of 2 Posts
Status
