Originally Posted by cybertec /forum/post/15442403
Go to www.Sanus.com , put in the PDP model, and it will show you what wall mount is good for your PDP, the one I use and that you can use is the Sanus VMPL2b" b for Black", it can be had at Home depot online orders only for $99, great deal.
Originally Posted by freddy14 /forum/post/15442637
Thanks. I went to the sight and it says I also need an adaptor. Do you recall needing extra parts? Also, there is the VMPL3 that looks like it doesnt need any extra parts.
Originally Posted by sharpjunkie /forum/post/15443787
can anyone recommend an articulating bracket for a 6020 that's less than 200$?
Originally Posted by jayzfelon /forum/post/15489619
monoprice has some good articulating mount that works with your tv
Originally Posted by jollyguy23 /forum/post/15613402
hi Freedy14,
You mentioned that you were able to use your VMPL2b to mount this tv. I have the same mount but i see it difficult to mount this tv.
The back placte is 32 inches wide but the holes on the back of the tv measures 33.5 inches.
Can you please tell me how you managed to install with your VMPL2b? Did you you anu extra adapters?
Originally Posted by Jimsaudiovideo /forum/post/15667338
Stumbled across a company which makes heavy gauge relatively low cost dual arm articulating mounts: erseaudio dot com . I have installed 7 so far with heavy TV's with great success. I have also used Mono price, but erse's is definately a heavier gauge steel. Cheaper then Sanus, and just a little more then Monoprice.
Hope this helps.
Jims AV
