My dedicated theater space is extremely narrow at about 11.5' and I'm seriously kicking around the idea of decoupling and DD on all walls and the ceiling (which is 8.5' tall). The biggest issue for me with these constraints is the placement of the surround speakers as there's just no room.
Ideally having them in-wall would save the most space but that has to kill any soundproofing or at least seriously hamper it and for the coin required to soundproof, that's a risk I'd rather not take.
So naturally, I look up at the ceiling but the same problem presents itself. Then, I stumble onto that rubber Dynabox product which looks interesting but I still hate the idea of cutting a hole in DD. That's when I see these Bogen pendant speakers listed on Amazon a few products below the Dynabox and I'm intrigued because I would only need to drill a small hole for the speaker wire which could easily - I think - be sealed up with acoustical caulk.
So am I crazy for thinking this is a good idea? The speakers are 16 ohm but they'd just be used for the mids and rears on a 7.1 setup.
Here's a link to what I'm talking about...
http://www.bogen.com/products/pdfs/nearpdfs/OPS1s.pdf
EDIT: I should also point out that I'm planning on dark grey walls with a black ceiling so I would, obviously, use the black version of these which should make them virtually invisible.
