Status
Not open for further replies.
1 - 3 of 3 Posts
I am pondering the idea of using some sort of fabric on the walls in my HT.. What is holding me back is the fact that I have never applied fabric to walls before, how hard is it? Are there any key things I should keep in mind for both shopping for the right fabric and when it comes time to apply the fabric to my walls? Any information you can provide me with will be greatly appreciated..
Wu-
First, search in here on "fabric" or "GOM" and you'll get lots of good info.
Second, you can go to my construction pages via the "new theater" link in my signature. I have a little bit of info on how I did my fabric which is very similar to how most have done.
Finally, its not that hard to do at all. A little planning and a little help (although, I just did my room 100% by myself) and you can do it no problem.
1 - 3 of 3 Posts
Status
