Wall Mount Bracket
241 Views 2 Replies 2 Participants Last post by  Dgheredia
2
Looking for some advice on attaching a bracket to my Samsung. The holes are recessed and I had to use 1 really long washer and a small one so there is no gap. I’m using the M8 screw. Is it safe to have the screws out this long? Picture attached.
See less See more
1 - 3 of 3 Posts
That should be fine. Older sony LCD TVs used a much longer extension on the upper holes when wall-mounting and it wasn't an issue.
The important thing is that the screw should have at least 5-6 turns of thread engagement regardless of what the screw passes through on the way to the TV.
___
Awesome, thanks for the reply!
1 - 3 of 3 Posts
