1 - 1 of 1 Posts
Discussion Starter · #1 · (Edited)
Hello. I hope someone can help me with my antenna installation.
I purchased my RCA ant3037 antenna, 2, 5 foot mast sections and a 12" stand off wall mount set up from solid signal but the wall mount did not come with any instructions. The mount does have a 3rd leg for the bottom bracket. It will be mounted to the rear of my 3rd story wall and extend above the roof. I can figure out how to put the mount together but not sure how far apart the upper and lower brackets should be. Can anyone that has used this type of mount offer any advice?
Also would it be a better idea to add a 3rd mast section to allow the brackets to be farther apart? I know the the mast can't extend higher than 10ft from the top bracket.
1 - 1 of 1 Posts
