Originally Posted by evanhunter /forum/post/0
I just mounted my Panny 42" Plasma on the wall and wantto run the wires through the wall now. I do not want to add a outlet in the middle of the wall so want to run the power wires in the wall. I do not have any insulation so I thought maybe about just dropping a metal conduit thru the wall and run the power wire through it? Is this really that much of a fire hazard that I cant just drop the tv power wire inside the hollow wall? Do I have to use conduit? Any other recomendations?
No one is going to tell you what you can or cannot do in your house...that being said, I personally would not do that in my house. I don't think that it a major fire hazard, although I think that it is illegal (against code) to run a power cord inside a wall cavity, conduit or not.
I would either do it properly (run a outlet behind your TV) or run a paintable raceway on the wall, and run all you wires inside there.
This has been discussed in detail before on this forum, I believe .
