Hey guys!!
I'm looking for a wall-mounted rack unit to mount my audio/video gear. I've found this wall-mount unit:
http://www.thetekhouse.com/swingatwalra.html
Does anyone know what the height of this unit is? I emailed the website but they didn't reply to me. Since its 12U high, I figure 12 x 1.75 = 21 inches.
This wall mount rack will be mounted inside of a cabinent. I have a little over 19 inches of mounting depth available to me. I have 30 inches of height available, but there is a lip on the cabinent so I coulnd't fit anything larger than 26 inches height in (unless I could somehow rotate the unit upwards inside.
The gear I want to mount is minimal, only including:
Voom STB (satellite TV)
DVD Player
Receiver
4x2 component switcher
And possibly a VCR
Do you think 12U is enough space for this?
Also, are the swining gate wall racks directional? I mean, can they be mounted to open either to the left or to the right?
Thank you kindly, I appreciate any help you have.
DVD Player
Receiver
And possibly a VCR
