Hi, folks. Another noob question as I try to put this HT together!
Running in-wall wiring throughout the room (12AWG). Plan is (most likely) to terminate L/C/R at wall plates, and run regular speaker wire with bananas each end between plates and speakers. (Some thought to purchasing the Dayton pre-mades from Parts-Express, but don't know if there will be any appreciable difference...)
But, for surrounds, I assume this won't work because there won't be enough (any) clearance for the plate, bananas, etc., even if you use speaker mounts - and most certainly not if you use dipole/bipole speakers which flushmount to the wall?
So, I guess for these ones I would just pull the in-wall through and attach directly to the speaker, without even a banana (or maybe use a spade)?
What are others doing in this situation?
Small concern about the look if I use speaker mounts, because there will be some distance from the wall - and I am planning to use the 12AWG in-wall from Home Depot, which is yellow/green color - not exactly pleasing to the eye....
