I need to decide on some wall mount rear surround speakers and can spend up to $500 Max (prefferably less). I am willing to go with either a dipole or bipole speaker. My equipment is the BK AVR 507, front speakers Monitor audio silver 7i in a room which is 16' x 33' (front speakers will be approx 25' from rears . I need to mount the rear surrounds on the wall. There are so many speakers in the $300-$500 range that I am getting too confused looking at all the specs. Any recomendations on good rear channel speakers. My one main issue is that the speaker layout needs to be close to the dimensions of the Klipsch 9"H x 11" W (wider than tall) I have been looking at the following
Cambridge sounworks Newton s300
Klipsch R3 II (worried it will be too bright)
Phase tech Theatro rear
Boston Acoustics VRMX
Monitor Audio Silver FXi Surrounds (too expensive)
Mirage Omnisat (only for rear channels, not the entire system)
Any other recommendations on these or other rear surrounds. Anybody's comments will be appreciated
Daso
Daso
