Status
Not open for further replies.
1 - 2 of 2 Posts
I want to optimize my sound system for a Optoma H57 projector. My room is 11' wide, 24' deep and 7' ceiling. I've looked at HTIB, but I know different companies produce different quality in speakers, recievers, and sub. The sound system will be solely used for movies and some video games. I would like 6.1 or 7.1. I'm looking to spend $1000-1500. Should I go with a HTIB or try to purchase speakers, receiver, and sub separtely? If so or not which speaker, receiver, sub combo will I be happy with given the amount of money I wish to spend.
P.S Since my room is 24' deep I was wondering if I need more powerful speakers in front to equilize the sound from the back. Thanks for your help!
Avoid a HTIB! Your budget is tight for a whole audio system, but certainly manageable if you make a budget and stick to it. Here's how I'd split it up:
Receiver: $300
DVD Player: $100-150
Subwoofer: $300-400
Speakers (6-7 speakers): Remainder of budget, but don't skimp here! For ~$100/speaker there are plenty of good choices.
Look for the best bang for the buck from each componant. There are lots of threads with recommendations for gear in these price ranges. Look around the forums, and listen to some gear. BTW, my only specific recommendations would be one of the smaller Hsu or Outlaw subs, and speakers which sounds good to you.
No, not really, but you'll want to position and calibrate them properly for your seating position.
Sure!
1 - 2 of 2 Posts
Status
