Want your stock car radio to deliver high quality output similar to that of an aftermarket head unit? The PXE-H650 can make any factory car radio sound like a high-quality Alpine head unit. It is an audio processor that is designed to allow consumers to upgrade their vehicle's sound system from the installed factory stereo system. The product is a sophisticated audio processor that allows for advanced sound tuning of factory equipment by correcting the acoustical problems in any vehicle on the market. The PXE-H650 is equipped with AntEQ, to remove the factory equalization, and Audyssey SoundEQ XT, to optimize the sound quality of the car's system.
AntEQ works by removing all factory equalization, bringing the factory system's EQ to a flat response and removing all distortion created by the system. It balances all sound levels using DSP power, and flattens the output signals so that Alpine amplifier and speaker upgrades can be added to the factory system.
After AntEQ has flattened the factory EQ, Audyssey SoundEQ XT then tunes the vehicle's system for optimum performance. The PXE-H650 uses an active feedback microphone to collect measurements from the vehicle's cabin. The unit then automatically tunes itself, making automatic adjustments for the in-cabin acoustics to create optimal sound quality. Audyssey SoundEQ XT adjusts time correction, frequency and phase in relation to each other. At this point, amplifiers, speakers and subwoofers could be added for a simple upgrade of the factory system, or a more complex system can be made if a full multi-channel set-up is desired. A powerful DSP processor allows for acoustic correction all the way down to 20 Hz on all channels. SoundEQ XT analyzes the entire frequency spectrum.
With this system, the troubles of installing head units in increasing complex vehicle dash units are a thing of the past. Just use the stock radio that came with your vehicle and turn your sound system into the beast that it wants to be!
Available Q1 2007. Price $400.
