1 - 3 of 3 Posts
The technology is out there, why aren't 16:10, thin-bezel, 120Hz+, low input lag LCDs/OLEDs for Nvidia Surround/AMD Eyefinity/Matrox TripleHead2Go setups available yet!?! Even though I love my setup , I know that these monitors won't last forever. When I have to replace them , it's definitely not going to be to some vertically cut-off 16:9 display!!
Unless of course, I go 5x1 16:9 ...
The demand for the product you want is probably shared by quite a few AVS members, but there is most likely not enough demand for companies to invest in designing, producing, and marketing an item like this.
BTW: Do none of the korean imports have these specs? I know some of them are 120hz but not sure of aspect ratio.
Discussion Starter · #3 ·
The important piece of this puzzle would be the 16:10 ratio. There are monitors out there in 16:9 that have these specs. However, the 16:10 ratio is absolutely perfect for 3x1 surround setups due to having more vertical real estate than 16:9.
1 - 3 of 3 Posts
