I live in Woodbridge, VA 22193; we receive our broadcasting from the Washington, DC market. My goal is to also receive all (ABC, CBS, NBC, FOX, and CW) of the Baltimore, broadcasting as well...
I assume you already know that all of those networks are available from the D.C. area and that you really do want the Baltimore stations.
Also that you have looked into streaming (e.g. WBAL news is free online).
AFAICT, your antenna is only rated for 45 miles. You are a lot further away - I'm amazed you can get Baltimore reliably (with the lights off). I wonder if replacing it with a longer range antenna (as well as raising it as high as you can, as you have suggested) would help.
I'm going to assume the antenna cable isn't picking up the signal. Then I wonder if you could shield your antenna from your lighting fixtures by placing sheet metal above the lights. But you don't want to overheat the lights by cutting air circulation. I'm not sure what putting a sheet of metal just below the antenna (but not touching or connected to the wires) would do - it might help, or might make things worse.
BTW, chicken wire might work as well as sheet metal. In any event, you could do a quick cheap test with aluminum foil. If that helps, a thicker metal sheet might do better.
At a guess (I could be wrong), wrapping the antenna wire with aluminum foil might help a bit, if the antenna wire is the problem. Or not.
Good luck!
