my channel 3 is getting a bit of interference (of course, it looks worse when recorded on the replaytv). channels 14 and 15 also have bad interference, but only when tuning with the TV with the replaytv off. anyway, i'm pretty sure it's a weak cable signal. it looks bad in the living room, but good in the bedroom.
i have two cables coming in from the street. the one going to the living room is split in two, then goes thru a diplexer, where it joins with the satellite signal. in the living room, it's coupled (wall plate), then goes thru another diplexer to separate sat and catv. now, the catv goes in to the replaytv, out into VCR, out from VCR in to TV.
long story short, i think i need a cable signal booster/amplifier. can someone indicate a decent one (i.e., not too expensive) and where in the cable line to put it?
also, while i'm at it, i'd like to find out more about in-home distribution systems, sooo if you could point me to a good web site...
TIA
TIA
