Background:
I recently purchased my first Plasma after years of CRT-based displays; a
Panasonic TC-P50V10. I just love the picture, but I wanted more. First I broke in the set using the appropriate colored images and settings. Then I applied the CNET settings and liked the picture even better, but I wanted more. So, I bought an
Eye 1 Display LT to calibrate the set. I practiced making adjustments only in the user menu's, and I liked the picture even better, but I wanted more. So I'm about to embark on adjusting the service menu settings, but a recent thread by ORTA sparked a question about my experience to date.
Observation:
While adjusting the gamma curve, I saw a huge difference in the gamma curve between using full fields vs. low average picture level ("APL") patterns. At higher luminance levels, the gamma curve just tanked. The display could not keep pumping out more lumens as the luminance increased when displaying full screen whites. Without changing any settings, just using a different APL test pattern, the gamma curve looked more appropriate.
Questions:
1. Is this normal behavior for a plasma, or am I doing something wrong?
2. If it's normal, or at least common, what is the best pattern to use when adjusting the gamma curve to compensate for this behavior (I'm using
Color HCFR with the
AVS HD 709 DVD in a
Sony PS3 for my source and HDMI for all signal paths)?
3. If this behavior is true for gamma testing, would similar artifacts be introduced into the color/gray scale dimensions during calibration with high APL patterns vs. low APL patterns? If so, what are the best patterns to use with the Eye 1 sensor?
Speculation:
Back in the CRT days, I think I remember specific test patterns that stressed the power supply with large white fields to determine how well the set could maintain light output in small vs. large areas of white. My recollection was that diminishing light output with increasingly larger white areas was an indication of a power supply with inadequate capacity.
Do I have a weak power supply in my new plasma, or am I just proving the severity of my dementia?
And before you say that rarely will you have full screen whites, let me add that I like to watch a lot of hockey...
Thanks for your input.
Mike
