1 - 2 of 2 Posts
· Registered
As the title says what resolution can you send a faux 4K projector. Jvc x790r in particular but many other take 4K use half the pixels and do the same thing. Could I then simpler send a half 4K resolution and not change the actual pixel density of the projector output. Or does this not work. Would be nice to add a bunch of FPS back to the games
· Super Moderator
JVC NZ9 | Sony 760ES | ST130 G4 135" | AVM-60 | MC303 &152 | 7.2.4: B&W 2x802D3/803D3/805D3| 4x15 IB
Send 3840x2160p to an x790r for best results
1 - 2 of 2 Posts
