Status
Not open for further replies.
1 - 20 of 95 Posts
This afternoon I turned in 32-1 and have a good signal and video, but no audio. I called into the station and now a couple of hours later I have audio but no video. Anyone else having problems today??? Thanks - Rick
Premium Member
Same here.
Discussion Starter · #4 ·
Originally posted by greywolf
Same here.
Thanks Pat, I called the newsroom number (312-565-5533) and asked them to let master control know, maybe they'll get it fixed by the time 24 is on tonight.
Great, it's 7:33pm and I don't have picture or audio. I checked OTA and cable, and neither are showing up.
Ack! 24 is less than a half hour away...
Gentlemen,
Sorry to report that our DTV encoder died. We're off the air for 24-48 hours, depending on how fast the Encoder Mfgr gets us a replacement.
I'm currently in Sunnyvale CA at our automation vendor doing system tests for our new WFLD/WPWR MCR buildout, so I am not in Chicago to be able to attempt a temporary fix.
Thanks for the update, Bob... at least we won't have to keep flipping back during commercials to see if the signal came back up.
Yeah, same problem here. Had to watch 24 through the lousy DirecTV feed instead of the enhanced widescreen! Couldn't this have happeded during the day instead of during 24!?!?!?!
Originally posted by kippjones
I am the only one here who watches American Idol?
Yes. As a matter of fact, you may be the only person anywhere that watches American Idol. :D
Mike K.
Premium Member
For sure you are the only person who will admit it publicly.
Haven't looked in on this forum for quite a while - I guess because the technology has actually been working!
This particular problem is manifesting itself very strangely in our home. The RCA F38310 with rooftop antenna tries to tune 32-1 but come up with a bad analog fox signal, the label says WITI-DT. Milwaukee?
Stranger still, the TS-160 upstairs with a set top antenna is getting a digital picture on 32-1, strong signal, but the picture is squeezed in, black bars on the sides, and doesn't resize-zoom as it usually does. Audio is fine.
Last, we watch American Idol - Go Ruben!
Well, WFLD is back up and running, but the aspect ratio is completely messed up - it's compressed horizontally. But hey, at least it's sorta back up...
Edit: Also just noticed that it identifies itself as channel 31.02.
Discussion Starter · #19 ·
Looks like the 'borrowed' an encoder from WITI, the Fox station in Milwaukee. My Dish 6000 is not remapping 31-1 to 32-1 and shows WITI, looks like there's a bit more work needed to be done.
1 - 20 of 95 Posts
Status
