Status
Not open for further replies.
1 - 5 of 5 Posts
VGA will be cheaper. www.pccables.com/cgi-bin/orders6.cgi?action=Showitem&id=ID533663&partno=00648&search= MONITOR&rsite=www.pccables.com&rcode= has cheap but good VGA cabling. They guarantee not to have ghosting. I bought their 15 footer ($13.50) and it works perfectly without any visible image degradation compared to the cheap 6 footer that came with my projector. Their cable has the magnets at the 2 ends to further shield from interference. It's also coax shielded so no interference. They have a 50 footer SVGA male to male cable for $30. They shipped my cable by ground and it came within 1 week. I'm very satisfied with their cable. Of course component allows you to vary the aspect and control color saturation while VGA is RGB so you'd have to change colors with your PC. You'd need a VGA switcher too since you want to input 2 sources into your projector. A good one can run $100-200. www.bettercables.com will be pricey and their cables are very good also. I'm just not sure if it's worth the price difference though.
Huey ;-]
Do a search for the long thread about RGBHV over shielded cat5 - if you're willing to solder a few ends you can get a better and cheaper cable from that than you can buy on the net, and the cable is more flexible (in every sense of the word).
Darren Rogers
God Bless America,
Land that I love.
Stand beside her, and guide her
Thru the night with a light from above.
From the mountains, to the prairies,
To the oceans, white with foam
God bless America, My home sweet home.
NEC VT540 & HTPC in my stealth theather
I will track down the thread. But it is hard for me to imagine that I could get the same quality of video signal through cat5.
If it is fact then that is great. I have cat 5 run all over the house.
George M
I need to run cables about 40' to my projector. It will be fed from satellite and computer.
What is the better cable to use from a computer --- component or vga?
George M
1 - 5 of 5 Posts
Status
