1 - 4 of 4 Posts
I am finalising an extension in my house and the builders are looking for drawings with details of cables to be run. just wondering what are the name/types of cables that can be speced on plans. appart from cat5.
thanks
Have them run Cat6 instead of Cat5. Price is almost the same now and it would be smart to futureproof yourself as much as possible while you still can.
RETIRED theater builder
The smartest move is to have a big (2 inch+) electrical conduit run in the walls from where your display will be to where your equipment stack will be. Then you can pull HDMI cables etc at a later date and not worry about what happens to an unprotected cable and cable ends that are hanging around during the construction process.
Depending on your display choice a HDMI cable may be all you need. It also depends on your receivers capabilities to switch various signals and what other gear you might want. For instance a Wii needs a component or composite cable but if your receiver will convert that signal to HDMI you can avoid running an extra cable.
You also need to determine if you need cable/satellite connections in the extension and pre-plan those wire runs.
1 - 4 of 4 Posts
