1 - 5 of 5 Posts
About to get the Emotiva Ultra Theater Combo and need to decide on the cables to connect the amp and pre pro.
Currently I am looking at the following 3 options:
PREMIUM 2 RCA Plug/2 RCA Plug M/M 22AWG Cable - 3ft
http://www.monoprice.com/products/pr...ormat=2&style=
High-quality Digital Coaxial Audio RCA Cable M/M RG6U 75ohm Gold connector S/PDIF Subwoofer
PCAs from Outlaw
http://www.outlawaudio.com/products/cab_pca_about.html
Will the first 2 options even work?
What are most people typically using here to connect their pre/pro and amp?
Any of those would work, though I don't know how well a coax digital cable would work as an interconnect for your pre/pro, but it would probably be fine. I don't think I'd spend the money on the outlaw cables though. As long as your interconnects are properly shielded, you should be OK. It's not necessary to spend hundreds on cables or speaker wire for that matter.
Discussion Starter · #3 ·
I'm actually wondering what is the difference between
regular RCA interconnect cable
Subwoofer cable
video composite cable
digital spdif coaxial cable
Component cable
The regular cheap rca interconnects that are usually thrown in can be used as a component cable. My dish installer hooked up the receiver with a regular rca cable to my plasma and it worked fine.
Hmm, didn't even know Outlaw sold cables... anyway the cheap cables from monoprice should be fine. I'm actually using that middle link one for my sub cable and my components cost a lot more than the cheap Emo pair.
Subwoofer cable
No differences.
Component cable
All specified as 75ohm and functionally equivalent.
All the above will work as analog audio interconnects.
1 - 5 of 5 Posts
