Status
Not open for further replies.
1 - 1 of 1 Posts
I just got my Sony 400Q back from service and cleaning. Last night, watching Band of Brothers on HBO HD, I noticed that in bright scenes, the skin tones would shift from purplish for just a moment or so to normal skin color. It was most noticeable on skin tones, but you could also see the uniforms go from purplish to the normal color. The lamp is new, and I'm using high quality component cables with Canare connectors. Any idea what might be causing this? I checked all my connections from my Sony HD100, and they're fine. Thanks for the help.
mike
1 - 1 of 1 Posts
Status
