1 - 3 of 3 Posts
· Registered
I have just finished putting newish tubes (07 MP) in a Sony 1271. Everything seems to be correct and installed properly.
However when i turn it on the green tube lights up and within 1 second goes super bright, so bright that i thought i was gonna blow up so i unplugged the power cable.
The other 2 tubes (red and blue ) are fine.
I dont get any error codes
what should i be looking at in order to fix this problem. Could it be a faulty tube?
· Registered
It could be, but I'll bet you bent a pin when you put the CRT socket back on. Check that first.
1 - 3 of 3 Posts
