What computer sound card for my system
220 Views 3 Replies 4 Participants Last post by  barhoram
Do i need a special sound card to get 5.1 with a digital or coaxial out? or can i just buy the adaptor that goes from headphone jack into 2 RCA's and get that sound?
Ive been lookin at some sound cards but not sure what to do. I am getting Onkyo TX-SR502 that has 1 coaxial and 3 digital inputs.
So my main question is... Will i get 5.1 (5.1 is good enough for computer and for now i only have 5 speakers) with a normal output if the sound card supports it by the adaptor or do i need the coaxial or digital outputs
Also, if using the digital output on Creative Labs® Sound Blaster® Live!™ 5.1 Dolby Digital PCI Sound Card, How would i connect that to my reciever.. Onkyo TX-SR502, the adaptor?
thanks, and sorry about like 20 questions in there :rolleyes:
Status
Not open for further replies.
1 - 4 of 4 Posts
You might have better luck posting on the HTPC forum. I only use my computer for AVSForum! :D
Jason
Coincidentally i was also looking for a similar adapter. I found one on tigerdirect for like 70 bucks. It connects to your USB port , and has coax and optical out. check it out. www.tigerdirect.com. i forgot what it was called, sorry. Look under sound cards.
most soundcards support digital out and have either a optical or coax connection on them.
1 - 4 of 4 Posts
Status
