1 - 8 of 8 Posts
Discussion Starter · #3 ·
where are they? you'd think of all people monoprice would have them
Or you could combine a M/M RCA cord with a F/F RCA Gender Changer...?
Banned
The monoprice page had couplers on it, so I do not think he wants couplers. What I think he wants is a long male to female RCA cable, aka RCA extension cable. That way he does not have to use a coupler.
Really, it is 6 of one, a half dozen of the other. Both work just as well. IMO, the coupler is better because they are more commonly used so you can get higher quality ones.
But for the RCA extension cable, you can find them here , here , here , and here .
The best thing to do is replace the original cable with a longer one so that you will not have a break in the chain...
1 - 8 of 8 Posts
