Jumping the fuse holder is a good way to ensure that the amp is either fully-dead now, or not fully-dead yet. It will definitely clear the fault.
You can get them at any HW store, but definitely online.
I believe they are just generic 30A 240V quick blow fuses.
You'll want to take each one out and test it with an ohm meter. If it reads 0-ohms then it is working, reinstall the working ones back where you took them out from.
You'll want to buy a pack of them because it might blow another set.
Yours appears to be fused at 60A, I assume you have the 120V model.
Drawing over 60A @ 240V would be quite the feat, even for a FP20k.
What were you powering with it?
Were you trying to weld IPAL-21's at 0-ohms at 194db... or what?
In any case, if you need a beefier amp you could get a pair of FP14k's, they run cooler, handle lower ohms better, and output slightly more power (6db bridged and 1-3db unbridged).
Or better yet: a used Gruppen PLM20k, those at least have PFC, 70-265v uni-supplies, legit trip protection, protection circuitry, load monitoring, DSP, (and more...)
Sounds like you clipped it to death and/or overheated it to death, perhaps.
Amps this powerful are capable of sagging the power grid, which can cause additional problems for the amp.
Did your UPS record any sag events by chance?
I run a dozen clones at 120V, and even though the line is 2awg I still manage to sag it from 120V to 105V and that still isn't anywhere near clipping yet. I probably should convert them all to 240V at some point, I'm sure the pole transformers and power company would be happier if I did.
