Will you be selling the defective amp?I’m prepared to just buy a new amp. We will see.
Jumping them even without a load, could have destroyed\damaged the amp further. But it powered on so I guess your 50/50 ticket was a winner by pure luck.This amp has a history. I did clip the piss out of the amps unknowingly a few times.
The amp is powering my rear hst-18’s and nearfield ds4’s.
Also, it’s a 120V amp, on a 30A dedicated circuit.
Someone on the dedicated forum ran fiber optic from the amp leds to somewhere subtle by the screen I think. Spent a few mins trying to find it and didn’t but it’s a great idea. Basically made a plate of mdf or such and aligned the fiber with the amp face and ran it to the front. I’m gonna order some fiber and play when I get a chance.Finally I decided to go see how they were during during the barrel roll scene. They were clipping
I believe GSG is currently doing a group buy on them, check their Facebook for the details.I just jumped the fuses to be sure it would turn on. Hopefully with no load at all there wouldn’t be a disaster. This amp has a history. It’s the one that got a new output board when it was doa. I did that replacement and it’s worked well ever since. But this probably is my fault. I’ve been pushing things because my room is a new remodel just to test out what’s changed. I did clip the piss out of the amps unknowingly a few times. Finally I decided to go see how they were during during the barrel roll scene. They were clipping.
Got cha.I think it's because 120v needs 60 amp fusing. 240v only requires 30 amp fusing.
If it is loud enough for you, then it isn't a problem.I really never messed around with any of the switches on the back of the FP20K since I installed it. I think i switched the one switch from hard to soft, but left everything else as is. Everything seems to work fine, but i can never get anything to register on the meters on the front. I see people talk about getting close to clipping, and i can blast bass heavy music and can't even get one bar. Not a complaint, but just want to make sure I shouldn't be playing with the switches for some reason.
Also, the room is small-ish and the amp is pushing 2 out of 4 subs in the room that are half the distance to my seating than the other two subs. So I'm thinking that just maybe I'm barely scratching the surface with this setup and the amp just doesn't need to work that hard to meet my needs.
Yes and they probably just couldn't find a 60a fuse in that form-factor.I think it's because 120v needs 60 amp fusing. 240v only requires 30 amp fusing.
Yeah. In a crazy twist, the fuses did their job. Lol. This amp has always had all channels driven.Good news! Thinking it just drew too much juice and popped the fuse? I was remembering the one that got fried in testing but not sure it was all channels driven, amp can probably draw too much through the one channel before it would blow the fuses. Good reminder to try to load all the channels and I guess look at the voltage limiter for the subs that can’t handle as much power.
The Crown iTech's have that also.Wonder if they could fit/use a resettable circuit breaker type switch like the speakerpowers have, for an upcharge.
