1 - 17 of 17 Posts
· Registered
Can it sound like a clanking sound? My UXL's weren't really moving that much P-P, so I don't see how it could have been them bottoming out.
Amp is a CV5000. It's being fed by a UMC-1.
Amp gain knobs are at the max. MiniDSP is boosting by ~4-6dB, and the sub trim level on the UMC is at "+10" (whatever that means).
  • Like
Reactions: Mfusick
· Registered
I think it can sound like clanking. I've had my system make very scary sounds and I've pegged it as clipping because there's no way my subs should bottom. They're in undersized boxes and severely underpowered too. The first time it happened I was very concerned. Its a rather frightening sound. As in frightened that your subs are bottoming. Not actually frightened.
· Registered
Discussion Starter · #3 ·
Originally Posted by tuxedocivic  /t/1524315/what-does-it-sound-like-when-incoming-voltage-clips-the-amp#post_24529936
This. I don't see how they could possibly have been bottoming, but it was still a scary sound.
  • Like
Reactions: Mfusick
· Registered
"What does it sound like when incoming voltage clips the amp?"
To me it sounds like a square wave - dirty, full of distortion
  • Like
Reactions: Rebel975
· Banned
Originally Posted by Rebel975  /t/1524315/what-does-it-sound-like-when-incoming-voltage-clips-the-amp#post_24529894
Yes, it can, especially if it's a hard clip. It can sound similar to coil smack.
· Registered
*poink"
· Registered
You are probably clipping at 2 places and neither has to do with the input voltage. All movies I've seen have peaks near 0 dBfs. First, if you are doing a gain in the MiniDSP without reducing the entire level in the MiniDSP first, then you can clip the signal.
Second, any pro amp can handle 24 dBu on the inputs which is 12.28 volts. Some can even handle 28 dBu which is 19.5 volts. You aren't outputting that much voltage with your MiniDSP and UMC-1 combined. The issue is that the input sensitivity of the amp is 1.42 volts. If your gain levels are at max on the amp, then you are trying to output too much voltage. Turn down the gain knob to compensate for the input voltage.
· Registered
Discussion Starter · #10 ·
Originally Posted by doublewing11  /t/1524315/what-does-it-sound-like-when-incoming-voltage-clips-the-amp#post_24530086
It has also been mention that an air leak can have similar sound.
Are you having issues? Trying to have your subs keep up with your mains?
I don't think so. Both subs have a layer of closed cell foam between the lip of the basket and the baffle. Also the speaker terminals and feet were very well sealed from the inside. I went kind of nuts with it TBH.
Originally Posted by desertdome  /t/1524315/what-does-it-sound-like-when-incoming-voltage-clips-the-amp#post_24530437
If I turn down the gain knobs on the amp- how do I compensate for the loss of bass? It seems that I have plenty of sub to spare, and should have plenty of amp, but yet I have trouble actually realizing it.
  • Like
Reactions: Mfusick
· Banned
Originally Posted by Rebel975  /t/1524315/what-does-it-sound-like-when-incoming-voltage-clips-the-amp#post_24530562
If you turn down the gain knobs on the amp, then you can boost the subwoofer trim level in your pre/pro. I am not sure how a MiniDsp effects this, though. I would recommend reading that thread over at HTshack with regards to optimizing gain structure.
· Registered
First gain match your pro amp with the pre and then bring your subs close to your MLP, preferably near-field placement, to avoid boosting extra trim levels in the pre and still achieve required SPL.
  • Like
Reactions: Rebel975
· Registered
Discussion Starter · #13 ·
Originally Posted by Martycool007  /t/1524315/what-does-it-sound-like-when-incoming-voltage-clips-the-amp#post_24531072
Thanks. Will do. Here
Originally Posted by braveheart123  /t/1524315/what-does-it-sound-like-when-incoming-voltage-clips-the-amp#post_24531595
They're already pretty close. It's a fairly small room. But I did the subwoofer crawl to see where the best placement would be.
· Registered
Originally Posted by Rebel975  /t/1524315/what-does-it-sound-like-when-incoming-voltage-clips-the-amp/0_100#post_24530562
Your gain knobs should be as high as they can without causing a maximum signal to clip. You can set your gain using the Setting Power Amplifiers section in the Rane guide.
You still need to make sure you aren't clipping the signal in the MiniDSP. Since the LFE channel is always mastered with peak levels near 0 dBfs, then you should reduce the input channel level by the amount of gain you are going to add in the Parametric EQ section. If adding 4 dB of boost, then pull down the input channel slider by 4 dB.
· Registered
The link for Setting Sound System Level Controls ( post 14 ) is mandatory for those starting out in Live sound where "blowing out" the Gain Structure is easy to do.
  • Like
Reactions: Rebel975
· Registered
I found this example of clipping sounds:
Something like this (play this through your subwoofer, but not too loudly).
Clipping.zip 579k .zip file
1 - 17 of 17 Posts
