HD receivers normally will convert 720p to 1080i.
Originally posted by peter0302 They don't downconvert to 480p. I would _guess_ that they take every two fields, de-interlace and smooth them, and show it twice for effective 720/30p. Or, they also might take every 540-line field, up it to 720, and then have effective 720/60p. Maybe the latter is more likely, although you wouldn't get quite the picture resolution, the temorals would be better. |
Originally posted by plasmamaniac Here's the deal. If you have 720P coming in and your display likes 720P as most plasmas then you're in business... |
