Status
Not open for further replies.
1 - 2 of 2 Posts
I want to be able to use the remote to control basic function...ie launch & control Theater tek and eventually other programs (winamp / music match). As well as power on and off the pc.
I assume a wireless keyboard can do most / all of this. Power on using ps2 port via key board power on option in bios. and Theater tek already has programmed hotkeys.
The idea is to get the keyboard up and running and then use a pronto remote to learn the appropriate keys.
Does this sound about right? or am I missing something.
which keyboard / mouse works the best and has the best range ect.
would I need girder...I think the other programs (regionkiller & ffdshow) load up when theatertek opens, so all I really need is a hot button to open theatertek (the latest patch finally enabled auto play correctly, so I guess I don't even need that)
Thanks for your help in boosting my WAF.
1 - 2 of 2 Posts
Status
