Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally posted by M NEWMAN Doubler = double the frame rate of standard NTSC video (480P, or progressive, vs 480i, or interlaced). Quadrupler = quadrupled frame rate, plus more pixels per line in some cases. 960P vs 480i. Scaler = flexibility to change resolution and refresh (frame) rate to any of several preset rates or anything you want, depending on model and sophistication (read that, cost). These are more suitable to CRT's because of the anamorphic and HDTV modes needing less resolution due to the fact that the lines are already being squeezed closer. Digital (fixed res) PJ's can also benefit from scalers in their ability to scale to exactly the native rate of the digital PJ's panels or chips. However, a lot of money can be saved by simply going to a good quality doubler due to the fact that you take the PJ out of the equation for the video decoding and the initial doubling duties. Most digital PJ's do a very good job of scaling up from 640 x 480 (480P), while doing a terrible job all the way from NTSC, up. |
Originally posted by Rohan I'm getting an NEC XG series PJ. Do I need to get a scaler or a quadrupler? I still don't understand the difference. Is it that a scaler is a flexible doubler / quadrupler? |
