Status
Not open for further replies.
1 - 7 of 7 Posts
I am adding a dish 501 to my dish 6023 system and have seen references to the two setups. I am not sure what LNBF setup I currently have. How do I tell? IF I add a 501 with current $200 offer will they let me have the other LNBF setup at no extra charge?
Gary
STOP DVI/HDCP!
DVI/HDCP! ~= HD-DIVX!!!
DO NOT SUPPORT JVC or anyone else who supports this!
The TWIN has a monolithic, single piece LNB with two coax terminals, and a built-in 4-2 switch. The TWIN can only drive two STBs. The two-dual LNB has two individual LNBs with two coax terminals each, for a total of four, and no switches. The advantage of the two-dual setup is that it can drive more than two STBs, but it will require suitable switches.
--Gerald C
STOP DVI/HDCP!
Discussion Starter · #4 ·
Thanks for the info. Exactly what I was looking for.
Question: Are all of the switches weatherproof or do I need to run all of the cables to an inside mounted switch?
Gary
STOP DVI/HDCP!
The switches themselves are weatherproof, but not the cables going to the switches nor the power insertors for the SW44 and SW64. If you decide to put your switches outside in the weather, be sure to take appropriate measures on your cabling.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/csb/facts/otard.html
Can you tell me more aboyt this $199 offer.
Discussion Starter · #7 ·
Sorry I thought I replyed to this.
The $199 offer includes a Dish PVR 501 installed and an upgrade to a dish 500 (if applicable). See there web site at www.dishnetwork.com
Gary
STOP DVI/HDCP!
1 - 7 of 7 Posts
Status
