I am seeking for your help and advise since my knowledge as far as audio is concerned is limited.
I have a system that includes the following:
1. A/V Yamaha RX-V2600
2. Front speakers: Focal_JM Lab SibXXL
3. Center and Suround speakers: Focal_JM Lab SibXL
4. Sub: Focal JM_Lab SW700S
The specs of the 2 front speakers are the following:
Type: 2 way bass-reflex floorstanding loudspeaker
Driver: 2x5" (2x13cm) Polyflex bass cones. OAL* 3/4" (19mm) aluminium tweeter dome.
Frequency response (+/- 3dB): 55Hz-35kHz
Sensitivity (2,83 V/1 m): 90dB
Max. power handling: 120W
Crossover: OPC 12dB/oct, 3,5kHz
Normal/min. impedance: 8 ohms/4 ohms
After having problems with my A/V in a party I held at home (the a/v kept shutting down when operated in 5-ch stereo and high volumes) people recommended to me to add a power amp to my system to drive the speakers and use the yamaha rx-v2600 as pre-amp. Others say that I should get a 2-ch power amp just for the 2 front spekers, others recommend 5-ch power amp for all the speakers while others believe that a 3-ch one just for the front and center would be enough.
I have the following questions:
1. If I add a power amp will I notice a difference in everyday use (watching movies and listening to music at normal volume) or the difference will only be noticable at high volumes? Will the quality of the sound improve regardless the volume level?
2. What should I choose? A 2-ch, a 3-ch or a 5-ch power amp?
3. Do you have any models to recommend? I don't want to spend too much. The cap would be around $1000-$1500. So far friends have recommended the 5-ch Rotel RB-1075 as great value for money solution, the 2-ch Audiolab 8000P as great pair for my speakers and the 2-ch Behringer EP-1500. What do you think?
