Status
Not open for further replies.
1 - 2 of 2 Posts
Hi guys
I,m in the middle of researching what I need to build a HCPC.
But I have a question and I hope someone can help.
I want to be able to connect the PC to a 32" widescreen TV, what is the best method, bearing in mind that I really dont want to have a PC Monitor present at all, using the TV as my main display.
The TV in question is a JVC model with 3 scarts, one of which is RGB enabled, which I havnt purchased as yet.
Thanks guys
Look forward to your responses.
go for the rgb one but you probably won't be able to get a resoloution over 640*480 but i don't know if the set will handle a progressive image. if it does, you could use DSCALER and deinterlace and clean up your picture a bit more. should look pretty damn good.
1 - 2 of 2 Posts
Status
