Status
Not open for further replies.
1 - 2 of 2 Posts
I have my Samsung 931 DVD Player hooked up to my HLN467 TV via DVI.
Since my Samsung is a 720 resolution....the DVI light/button on the DVD player should be set to BLUE since that is the 720p setting. No matter what the aspect ration of the DVD is . Always 720p setting on DVD playerRight????
I just want to be sure about this.
THank you to whoever can solidify this for me.
That's correct. That gives a direct signal path, with no additional processing.
I don't do games, so I hooked up the component output as well. That way, when you watch faked-you-out-widescreen movies like The Dirty Dozen, which I watched today, you can just switch the TV over from DVI to component 1 and watch it there. Also handy for 4:3 aspect ratio movies.
1 - 2 of 2 Posts
Status
