1 - 5 of 5 Posts
all the lower end economy projectors ive looked at (w1070 and others) wont give me a long enough throw , I need a 16 to 17 foot throw distance and no more than 110 inch 16:9 screen size, but the only one ive found is the epson 3020, which the black levels could be the deal breaker,
Oh , im also looking for ones that are 3D equipped as well.
Closest thing right now are the Optomas, which will give 122" diagonal from a 16-foot throw.
The BenQ W1300 could zoom in to 106" at sixteen feet. Too bad it isn't available in the US -- I'd be right behind you if it were.
Discussion Starter · #4 ·
I wanted to be around the 1000 mark, I wasn't expecting to get lens shift for that, if I can't find something I may have to consider a re-furbwd 5020 which has it all, but at almost twice my budget
1 - 5 of 5 Posts
