Status
Not open for further replies.
1 - 2 of 2 Posts
I have a pair or Epos ELS3's in the front, the ELS3C center and a Velodyne VRP-1200 subwoofer. I didn't really want to got with the full Epos 5.1 set because I thought their sub was too pricey and that another set of ELS3's for the rear would be overkill. The problem is that all the quality rear channels I find cost more than my Epos's.
Can anyone recommend a quality set for under $300 that will go well with my other components?
Well if your budget is $300 why not just get another set of ELS 3's? They can be had within your budget.
I got the ELS 5.1 setup from a dealer on Audiogon for a hair under $1200 and have been very very happy.
1 - 2 of 2 Posts
Status
