Hi everyone,
Quite frankly, I am at a loss and don't know what to do. I have researched these forums and am still bewildered, so I ask for some help please.
I have a new Pioneer 912K receiver being used with 2 new Def. Tech. 2002tl fronts (wired with a 14 gage speaker cable as all other channels), a 2500 center, and 2 bp2x surrounds.
The problem is that when I try to play movies or music with a lot of information at high levels (about 95db output read with a RS DB meter) the pioneer shuts down with an overload in about 3 seconds or less. I can keep it going with about a top level of around 90 db or a little less.
I believe I have read enough to understand that the reason is that the pioneer just can't handle it although I guess I had did my research and thought it would. I know the speakers can have an impeadance in the range of 4-8 ohms.
Well anyhow, I now have spent considerable time trying to figure out what receiver may do better in the ~$1000 or less range, without comming to a conclusion, and this is where I need the help with anything you may suggest.
I thank you in advance,
