I would like to keep it under $1000. New or used, sound quality is important as is power. It will have to drive 5 M&K's. My HK AVR75 with the M&K's sounds great with music as well as movies but shuts down all the time, I don't know if it's a heat issue or not, because sometimes it shuts down without anything playing through it. It used to just shut down once in a while but now I have to do something about it. I'm not sure if I want to bother getting it fixed as it's already been in the shop once and it doesn't have pro logic II or another digital input for future technology.
I just bought a Panasonic TH-50PX600U and I assume I can plug my dvd player right into it and won't need the receiver to do the switching? I talked to a salesman at Magnolia when I was looking at plasma's, and he mentioned that most receivers are going to have trouble driving the M&K's and I'd need something that could handle the 4 ohm load. I'd like to get something that would make the M&K's sound great and have features that wouldn't make it a dinosaur. Enough inputs for my cablebox/tivo, dvd, blueray? and some processing for 2 channel audio like dolby pro logic II.
