1 - 9 of 9 Posts
· Registered
My front speakers have 5.25" drivers and can get fairly low. My surrounds have 2.5" drivers. Basically zero bass.
I plan on upgrading the surrounds eventually, but in the meantime where should the crossover be? Should I base it off the size of the fronts or the surrounds?
The surrounds I'm using currently have a low of 280 Hz I believe (Bose doesn't give out specs), while the fronts are 53 Hz. I'm using a Yamaha sub that can shake the room so I'm good there.
· Premium Member
The crossover is really based on the acoustics of the room and placement not what the speakers are capable of. THX set the standard at 80Hz. This is not by accident. THX had specified that if speakers are 3.5 feet away from the front wall, in order to mitigate SBIR, we should set it to 4 times the distance which is 14 feet. The wavelength of 14 feet is 80Hz. So, it really boils down to what the distance of the acoustic center of the speaker is from the back and side walls.
· Registered
Does your receiver have only one crossover setting? I have owned four receivers in the past ten years including Sony, Denon and Marantz and they all have separate crossover settings for the mains and the surrounds.
· Registered
Discussion Starter · #4 ·
It looks that way. The receiver is over 15 years old but still working fine. There are separate EQ and volume settings for each speaker but I don't see crossover listed individually. There are six settings from 40-150Hz. I'll play around with it some more to make sure.
I may be replacing the surrounds with Polk S10s that have a frequency closer to the fronts.
· Super Moderator
JVC NZ9 | Sony 760ES | ST130 G4 135" | AVM-60 | MC303 &152 | 7.2.4: B&W 2x802D3/803D3/805D3| 4x15 IB
Yes but this assumes the speakers are capable. THX doesn't account for a 2.5" tweeter running rear surrounds lol.
  • Like
Reactions: LeoRavus
· Registered
Discussion Starter · #8 · (Edited)
They're actually Bose acoustimass double satellites that went to the old surround I sold most of years ago. lol I'm in the process of putting something else together.
I'm not sure if I'm even supposed to be running the doublshots without the original bass module. I'm seeing conflicting stories online. Just ordered the Polk S10s.
· Premium Member
True dat.
1 - 9 of 9 Posts
