What strange beasts subwoofers be...
611 Views 3 Replies 4 Participants Last post by  Jakeman02
Many thanks to the people here who have advised me to experiment with the placement of my troubled sub. With my cramped furniture filled room and my short cable, I was extremely limited with my choices. Putting somewhere to the right of my TV was bringing sad results. My only other choice was to put it exactly halfway down the right wall. Well despite the advice of my owners manual, I did place it in the middle of the right wall. The difference was astonishing, my good old system had regained the depth of sensation it had in the previous room.
While I am on the subject, I have a related question:
When I use the SPL to calibrate the speaker level, the sub is the only one that gives unstable readings. When I attempt to fine tune it to 85db, it seems to fluctuate unpredictably between 80-87db (regardless of the subs position). Is this a limitation of the meter? Or is it more indicitive of an acoustical problem in my room?
TIA,
Will
Status
Not open for further replies.
1 - 4 of 4 Posts
When I use the SPL to calibrate the speaker level, the sub is the only one that gives untable readings. When I attempt to fine tune it to 85db, it seems to fluctuate unpredictably between 80-87db (regardless of the subs position). Is this a limitation of the meter? Or is it more indicitive of an acoustical problem in my room?
TIA,
Will
It is a limitation of the meter's ability to accurately measure those low frequencies. Typically, the meter is not able to read those low frequencies as well. Your readings will most likely be less than the actual SPL by as much as 6db to 10db.
See less See more
That's nothing- what about the subwoofer owners?!?!?
Just use an average reading when calibrating the sub with the RS meter. If the needle flluctuates from 72 - 78, use 75 for your reading. Just leave it on at the same level for a minute or so and take the average. Vibratioins in the room can also cause it to fluctuate more, doors ratteling, blinds, furniture, nic naks placed in the room etc so try to pinpoint those to if you have any but it's normal for the needle to move up and down when calibrating the sub.
1 - 4 of 4 Posts
Status
